Towards Automatic Specialization of Java Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Automatic program specialization can derive efficient implementations from generic components, thus reconciling the often opposing goals of genericity and efficiency. This technique has proved useful within the domain of imperative languages, but so far it has not been explored within the domain of object-oriented languages. We present experiments in the specialization of Java programs. We demonstrate how to construct a program specializer for Java programs from an existing specializer for C programs and a Java-to-C compiler. Specialization is managed using a declarative approach that abstracts over the optimization process and masks implementation details. Our experiments show that program specialization provides a four-time- s speedup of an image-filtering program. Based on these experiments, we identify optimizations of object-oriented programs that can be carried out by automatic program specialization. We argue that program specialization is useful in the field of software components, allowing a generic component to be specialized to a specific configuration.
Autre [cs.OH]
RR-3579.pdf (268.31 Ko) Télécharger le fichier
inria-00073102 , version 1 (24-05-2006)
  • HAL Id : inria-00073102 , version 1
Ulrik Pagh Schultz, Julia L. Lawall, Charles Consel, Gilles Muller. Towards Automatic Specialization of Java Programs. [Research Report] RR-3579, INRIA. 1998. ⟨inria-00073102⟩
126 Consultations
312 Téléchargements
