A Quasi-Score Marginal Approach in Generalized Linear Mixed Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
This report deals with the problem of parameter estimation in generalized linear mixed models. Gilmour, Anderson, et Rae (1985) proposed a method of estimation in a probit link model for binomial data. Foulley et Im (1993) adapted this method to Poisson data in a log link model. We propose a unifying formal description including also the case of exponentia- l data in a log link model. This approach enables us to consider other cases such as logit link model for binomial data. Numerical examples are given to illustrate the method.
RR-3522.pdf (230.54 Ko) Télécharger le fichier
inria-00073162 , version 1 (24-05-2006)
  • HAL Id : inria-00073162 , version 1
Catherine Trottier. A Quasi-Score Marginal Approach in Generalized Linear Mixed Models. RR-3522, INRIA. 1998. ⟨inria-00073162⟩
40 Consultations
155 Téléchargements
