Weighted Error Estimators for the Incompressible Navier-Stokes Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
We present the application of weighted a posteriori error estimation to the incompressible Navier-Stokes equations. Using information from an appropriate dual problem, we control the discretization error of a functional of the solution as the drag or lift coefficient of an object immerged in a fluid. As test cases we consider a benchmark problem of a chanel flow and the flow around a cylinder in an unbounded domain.
Autre [cs.OH]
RR-3458.pdf (1006.75 Ko) Télécharger le fichier
inria-00073232 , version 1 (24-05-2006)
  • HAL Id : inria-00073232 , version 1
Roland Becker. Weighted Error Estimators for the Incompressible Navier-Stokes Equations. RR-3458, INRIA. 1998. ⟨inria-00073232⟩
53 Consultations
202 Téléchargements
