Long Time Behavior of the Two-Dimensional Vlasov Equation with a Strong External Magnetic Field - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2000
When charged particles are submitted to a large external magnetic field, their movement in first approximation occurs along the magnetic field lines and obeys a one dimensional Vlasov equation along these field lines. However, when observing the particles on a sufficiently long time time scale, a drift phenomenon perpendicular to the magnetic field lines superposes to this first movement. In this report, we present a rigorous asymptotic analysis of the two-dimensional Vlasov equation when the magnetic field tends to infinity, the observation time scale growing accordingly. Techniques based on the two-scale convergence and the introduction of a second problem enable us to find an equation verified by the weak limit of the distribution function.
RR-3428.pdf (226.04 Ko) Télécharger le fichier
inria-00073262 , version 1 (24-05-2006)
  • HAL Id : inria-00073262 , version 1
Emmanuel Frénod, Eric Sonnendrücker. Long Time Behavior of the Two-Dimensional Vlasov Equation with a Strong External Magnetic Field. Mathematical Models and Methods in Applied Sciences, 2000, 10 (4), pp.539--553. ⟨inria-00073262⟩
Collections
INRIA IRMA INRIA2
149 Consultations
296 Téléchargements
