Symbolic Composition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
The deforestation of a functional program is a transformation which gets rid ofintermediate data structures constructions that appear when two functions are composed. The descriptional composition, initially introduced by Ganzinger and Giegerich, is a deforestation method dedicated to the composition of two attribute grammars. This article presents a new functional deforestation technique, called symbolic composition, based on the descriptional composition mechanism, but extending it. An automatic translation from a functional program into an equivalent attribute grammar allows symbolic composition to be applied, and then the result can be translated back into a functional program. This yields a sourceto source functional program transformation. The resulting deforestation method provides a better deforestation than other existing functional techniques. Symbolic composition, that uses the declarative and descriptional features of attribute grammars is intrinsically more powerful than categorical-flavored transformations, whose recursion schemes are set by functors. These results tend to show that attribute grammars are a simple intermediate representation, particularly well-suited for program transformations.
RR-3348.pdf (315.78 Ko) Télécharger le fichier
inria-00073341 , version 1 (24-05-2006)
  • HAL Id : inria-00073341 , version 1
Loïc Correnson, Étienne Duris, Didier Parigot, Gilles Roussel. Symbolic Composition. [Research Report] RR-3348, INRIA. 1998. ⟨inria-00073341⟩
206 Consultations
346 Téléchargements
