On the Curves that may be approached by Trajectories of a Smooth Control Affine System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1997
In this paper, we give a characterization of the set of curves that may be approached by trajectories of a smooth control-affine nonlinear system, in the topology of uniform convergence. This characterization is in terms of the drift vector field and the distribution spanned by the Lie algebra generated by the control vector fields. The characterization is valid on open sets where this distribut- ion has constant rank. These results also characterize the support of diffusion processes with smooth coefficients.
Autre [cs.OH]
RR-3323.pdf (261.55 Ko) Télécharger le fichier
inria-00073366 , version 1 (24-05-2006)
  • HAL Id : inria-00073366 , version 1
Jean-Baptiste Pomet. On the Curves that may be approached by Trajectories of a Smooth Control Affine System. RR-3323, INRIA. 1997. ⟨inria-00073366⟩
60 Consultations
98 Téléchargements
