Removing Degeneracies by Perturbing the Problem or the World - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1997
Pierre Alliez
Olivier Devillers
Jack Snoeyink
  • Fonction : Auteur
We describe two problem-specific approaches to remove geometric degeneracies that we call {\it perturbing the problem} and {\it perturbing the world}. Using as our primary examples 2-d and 3-d Delaunay triangulation with Euclidean and polygonal metrics, we show that these approaches lead to relatively simple and efficient perturbations of the points that do not depend on a fixed ordering or index. Thus, they produce canonical output, which is important for producing test suites and verifiers for randomized or dynamic geometric algorithms.
RR-3316.pdf (322.02 Ko) Télécharger le fichier
inria-00073373 , version 1 (24-05-2006)
  • HAL Id : inria-00073373 , version 1
Pierre Alliez, Olivier Devillers, Jack Snoeyink. Removing Degeneracies by Perturbing the Problem or the World. RR-3316, INRIA. 1997. ⟨inria-00073373⟩
107 Consultations
347 Téléchargements
