HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Partial Order Control and Optimal Control of Discrete Event Systems modeled as Polynomial Dynamical Systems over Galois fields
Hervé Marchand 1 Michel Le Borgne 1
1 EP-ATR - Environnement de programmation d'applications temps réel
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : In this paper, we propose computational methods for the synthesis of controllers for discrete event systems modeled by polynomial dynamical systems over finite Galois field. The control objectives are specified as order relations to be checked and as minimization of a given cost function over the states through the trajectories of the system. The control objectives are then synthesized using algebraic tools such as ideals, varieties and morphisms. The applications of these methods to the safety specification of a power transformer station controller is finally presented.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00073416
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 12:44:51 PM
Last modification on : Friday, February 4, 2022 - 3:22:00 AM
Long-term archiving on: : Sunday, April 4, 2010 - 11:45:53 PM
Identifiers
  • HAL Id : inria-00073416, version 1
Citation
Hervé Marchand, Michel Le Borgne. Partial Order Control and Optimal Control of Discrete Event Systems modeled as Polynomial Dynamical Systems over Galois fields. [Research Report] RR-3273, INRIA. 1997. ⟨inria-00073416⟩
Share
Metrics
Record views
108
Files downloads
61
