Optimization of an LU Factorization Routine Using Communication/Computation Overlap - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
This report presents some works on the $LU$ factorization from the ScaLAPACK library. First, a complexity analysis is given. It allows to compute the optimal block size for the block scattered distribution used in ScaLAPACK. It also gives the communication phases that are interesting to overlap. Second, two optimizations based on computations/communications overlap are given with experimental results on Intel Paragon and IBM SP2 systems.
Autre [cs.OH]
RR-3094.pdf (345.85 Ko) Télécharger le fichier
inria-00073597 , version 1 (24-05-2006)
  • HAL Id : inria-00073597 , version 1
Frédéric Desprez, Stéphane Domas, Bernard Tourancheau. Optimization of an LU Factorization Routine Using Communication/Computation Overlap. [Research Report] RR-3094, INRIA. 1997. ⟨inria-00073597⟩
136 Consultations
642 Téléchargements
