A Nonparametric Goodness-of-fit Test for a Class of Parametric Autoregressive Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
We derive a nonparametric test for discriminating between generalized autoregressive models. This test is based on a suitably normalized sum of residuals. The null distribution and the power of the test under both fixed and a sequence of local alternatives are studied under mild stationarity and $\alpha$--mixing conditions. This procedure can be applied to testing linear models against nonlinear models or certain nonlinear models against others. Numerical simulations show that the proposed test is powerful against most of the alternatives considered.
RR-3065.pdf (340.68 Ko) Télécharger le fichier
inria-00073627 , version 1 (24-05-2006)
  • HAL Id : inria-00073627 , version 1
Joseph Ngatchou Wandji. A Nonparametric Goodness-of-fit Test for a Class of Parametric Autoregressive Models. RR-3065, INRIA. 1996. ⟨inria-00073627⟩
137 Consultations
279 Téléchargements
