Icobj Programming
Frédéric Boussinot 1
1 MEIJE - Concurrency, Synchronization and Real-time Programming
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : A simple and fully graphical programming method is presented, using a powerful means to combine behaviors. This programming is based on the notion of an «icobj» which has a behavioral aspect («object» part), a graphical aspect («icon» part), with an «animation» aspect. Icobj programming provides parallelism, broadcast event communication and migration through the network. An experimental system based on this approach is described in details. Its implementation with reactive scripts is also presented.
Type de document :
Rapport
RR-3028, INRIA. 1996
Liste complète des métadonnées
https://hal.inria.fr/inria-00073665
Contributeur : Rapport de Recherche Inria <>
Soumis le : mercredi 24 mai 2006 - 13:26:41
Dernière modification le : samedi 27 janvier 2018 - 01:31:29
Document(s) archivé(s) le : dimanche 4 avril 2010 - 23:54:06
Fichiers
  • HAL Id : inria-00073665, version 1
Collections
Citation
Frédéric Boussinot. Icobj Programming. RR-3028, INRIA. 1996. 〈inria-00073665〉
Métriques
Consultations de la notice
98
Téléchargements de fichiers
59
