Abstract : This paper deals with the detection of emerging plane cracks, by using boundary measurements. An identifiability result (uniqueness of the solution) is first proved. Then, we look at the stability of this solution with respect to the measurement. A weak stability result is proved, as well as a local Lipshitz stability result for straight cracks, by using domain-derivative techniques.
