Distributed Architecture for Programming Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
Laurence Rideau
  • Fonction : Auteur
  • PersonId : 832430
We present a technology used to transform a monolithic programming environment into a heterogeneous distributed system. We propose a communication protocol adapted to message passing between components in this new architecture. This protocol allows structured data transfer and remote operations. It has been implemented and is used in the {\sc centaur} programming environment generator.
RR-2918.pdf (114.32 Ko) Télécharger le fichier
inria-00073779 , version 1 (24-05-2006)
  • HAL Id : inria-00073779 , version 1
Anne-Marie Dery, Laurence Rideau. Distributed Architecture for Programming Environments. RR-2918, INRIA. 1996. ⟨inria-00073779⟩
66 Consultations
77 Téléchargements
