Exponential Bounds with Applications to Call Admission - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
In this paper we develop a framework for computing upper and lower bounds of an exponential form for a large class of single resource systems with Markov additive inputs. Specifically, the bounds are on quantities such as backlog, queue length, and response time. Explicit or computable expressions for our bounds are given in the context of queueing theory and numerical comparisons with other bounds are presented. The paper concludes with two applications to admission control in multimedia systems.
RR-2865.pdf (380.32 Ko) Télécharger le fichier
inria-00073826 , version 1 (24-05-2006)
  • HAL Id : inria-00073826 , version 1
Zhen Liu, Philippe Nain, Don Towsley. Exponential Bounds with Applications to Call Admission. RR-2865, INRIA. 1996. ⟨inria-00073826⟩
29 Consultations
168 Téléchargements
