Abstract : The «arrowhead torus» is a broadcast graph that we define on the 6-valent grid as a Cayley graph. A 3-port wormhole broadcasting protocol is derived first from construction, then improved by using edge-disjo- int forests. A store-and-forward broadcasting protocol is derived afterwards, then improved by mixing pipelining and arc-disjoint spanning trees. Costs are given in constant and linear time and compared with lower bounds.
