A Domain Decomposition Method for the Helmholtz Equation and Related Optimal Control Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1996
Jean-David Benamou
  • Fonction : Auteur
  • PersonId : 833568
Bruno Desprès
We present an iterative domain decomposition method to solve the Helmholtz equation and related optimal control problems. The proof of convergence of this method relies on energy techniques. This method leads to efficient algorithms for the numerical resolution of harmonic wave propagation problems in heterogeneous media and their control.
RR-2791.pdf (1.1 Mo) Télécharger le fichier
inria-00073899 , version 1 (24-05-2006)
  • HAL Id : inria-00073899 , version 1
Jean-David Benamou, Bruno Desprès. A Domain Decomposition Method for the Helmholtz Equation and Related Optimal Control Problems. [Research Report] RR-2791, INRIA. 1996. ⟨inria-00073899⟩
163 Consultations
1588 Téléchargements
