Reasoning with Executable Specifications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
Yves Bertot
Ranan Fraer
  • Fonction : Auteur
Starting from the specification of a small imperative programming language, and the description of two program transformations on this language, we formally prove the correctness of these transformations. The formal specifications are given in a single format, and can be compiled into both executable tools and collections of definitions to reason about into a theorem prover. This work is a case study of an environment integrating executable tool generation and formal reasoning on these tools.
RR-2780.pdf (314.48 Ko) Télécharger le fichier
inria-00073912 , version 1 (24-05-2006)
  • HAL Id : inria-00073912 , version 1
Yves Bertot, Ranan Fraer. Reasoning with Executable Specifications. RR-2780, INRIA. 1996. ⟨inria-00073912⟩
53 Consultations
180 Téléchargements
