Upper and Lower Bounds on Overflow Probabilities for a Multiplexer with Multiclass Markovian Sources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1995
In this paper, we consider a multiplexer with constant output rate and infinite buffer capacity fed by independent Markovian fluid on-off sources. We do not suppose that the model is symmetrical: there is an arbitrary number $K$ of different traffic classes, and for each class $k$, an arbitrary number $N_k$ of sources of this class. We derive lower and upper bounds for the stationary distribution of the backlog $X$ of the form $B\exp(-\theta^\star~x) \leq P{X>x} \leq C\exp(-\theta^\star~x)$. When $K=2$ or $K=1$, we numerically compare our bounds to the exact distribution of $X$ and to other previously known results. Through various examples, we discuss the behavior of $P{X>x}$ and the tightness of the bounds.
RR-2734.pdf (308.18 Ko) Télécharger le fichier
inria-00073959 , version 1 (24-05-2006)
  • HAL Id : inria-00073959 , version 1
Damien Artiges, Philippe Nain. Upper and Lower Bounds on Overflow Probabilities for a Multiplexer with Multiclass Markovian Sources. RR-2734, INRIA. 1995. ⟨inria-00073959⟩
61 Consultations
78 Téléchargements
