A piecewise line-search technique for maintaining the positive definiteness of the matrices in the SQP method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Optimization and Applications Année : 2000
Paul Armand
Jean Charles Gilbert
A technique for maintaining the positive definiteness of the matrices in the quasi-Newton version of the SQP algorithm is proposed. In our algorithm, approximations of the Hessian of the augmented Lagrangian are updated. The positive definiteness of these matrices in the space tangent to the constraint manifold is ensured by a piecewise line-search technique, while their positive definiteness in a decoupled complementary subspace is obtained by setting the augmentation parameter. The combination of these two ideas makes the new approach more robust in our experiment with respect to existing approaches
RR-2615.pdf (358.83 Ko) Télécharger le fichier
inria-00074070 , version 1 (24-05-2006)
Paternité
Paul Armand, Jean Charles Gilbert. A piecewise line-search technique for maintaining the positive definiteness of the matrices in the SQP method. Computational Optimization and Applications, 2000, 16, pp.121-158. ⟨10.1023/A:1008701324575⟩. ⟨inria-00074070⟩
98 Consultations
79 Téléchargements
