Reports
Adaptable Replicated Objects in Distributed Environments
Georges Brun-Cottan 1 Mesaac Makpangou 1
1 SOR - Distributed Object Systems
Inria Paris-Rocquencourt
Abstract : This paper presents an architecture and a run-time support environment for adaptable replicated objects. The architecture separates the type-specific logic of a replicated object, e.g.\ concurrency control, from the generic logic, e.g. consistency management. A replicated object is structured into components with generic interfaces. A programmer can adapt a replicated object to the application specifics by replacing components that implement generic logic. Our architecture, while making the replicated object flexible, does not preclude optimizations based on object semantics or on application specifics. A tool-box of ready-to-use objects reduces development cost for new replicated object types.
Document type :
Reports
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/inria-00074090
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:30:05 PM
Last modification on : Friday, February 4, 2022 - 3:07:26 AM
Long-term archiving on: : Sunday, April 4, 2010 - 9:52:06 PM
Identifiers
  • HAL Id : inria-00074090, version 1
Collections
Citation
Georges Brun-Cottan, Mesaac Makpangou. Adaptable Replicated Objects in Distributed Environments. [Research Report] RR-2593, INRIA. 1995. ⟨inria-00074090⟩
Share
Metrics
Record views
1750
Files downloads
14997
