Optimality and non-preemptive real-time scheduling revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
In this paper, we investigate the non-preemptive scheduling problem as it arises with single processor systems. We extend some previously published results concerning preemptive and non-preemptive scheduling over a single processor. We examine non-idling and idling scheduling issues. The latter are of particular relevance in the case of non-preemption. We first embark on analyzing non-idling scheduling. The optimality of the non-idling non-preemptive Earliest Deadline First scheduling policy is revisited. Then, we provide feasibility conditions in the presence of aperiodic or periodic traffic. Second, we examine the concept of idling scheduling, whereby a processor can remain idle in the presence of pending tasks. The non-idling non-preemptiv- e Earliest Deadline First scheduling policy is not optimal since it is possible to find feasible task sets for which this policy fails to produce a valid schedule. An optimal algorithm to find a valid schedule (if any) is presented and its complexity analyzed. This paper shows that preemptive and non-preemptive scheduling are closely related. However, non-preemptive scheduling leads to more complex problems when combined with idling scheduling.
Autre [cs.OH]
RR-2516.pdf (422.69 Ko) Télécharger le fichier
inria-00074162 , version 1 (24-05-2006)
  • HAL Id : inria-00074162 , version 1
Laurent George, Paul Mühlethaler, Nicolas Rivierre. Optimality and non-preemptive real-time scheduling revisited. [Research Report] RR-2516, INRIA. 1995. ⟨inria-00074162⟩
459 Consultations
682 Téléchargements
