HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Calibration Radiométrique de Caméra
Abstract : In Computer Vision methods such as shape-from-shading, 3D reconstruction by correlation and edge detection, all the pixels of the CCD matrix are assumed equivalent. A radiometric camera calibration step is necessary to verify this hypothesis, which is the subject of this paper. First, the modeling of the sensor, based on its physical properties, is described. A method to estimate the parameters of this model is given and the results of experimentations are described. These experiments valid the complete model only partially, and simplifications of this model are subsequently proposed which remain experimentally correct with focal length variations. Finally, improvements of the image analysis process after performing radiometric calibration are demonstrated.
Document type :
Reports
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/inria-00074169
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 2:39:40 PM
Last modification on : Thursday, February 3, 2022 - 11:18:44 AM
Long-term archiving on: : Monday, April 5, 2010 - 12:06:17 AM
Identifiers
  • HAL Id : inria-00074169, version 1
Collections
Citation
Jean-Philippe Tarel. Calibration Radiométrique de Caméra. [Rapport de recherche] RR-2509, INRIA. 1995, pp.20. ⟨inria-00074169⟩
Share
Metrics
Record views
261
Files downloads
824
