Mellin Transforms and Asymptotics: Harmonic Sums - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Xavier Gourdon
  • Fonction : Auteur
Philippe Dumas
This survey presents a unified and essentially self-contained approach to the asymptotic analysis of a large class of sums that arise in combinatorial mathematics, discrete probabilistic models, and the average case analysis of algorithms. It relies on the Mellin transform, a close relative of the integral transforms of Laplace and Fourier. The method applies to harmonic sums that are superpositions of rather arbitrary ``harmonics'' of a common base function. Its principle is a precise correspondence between individual terms in the asymptotic expansion of an original function and singularities of the transformed function. The main applications discussed are in the area of digital data structures, probabilistic algorithms, and communication theory.
Autre [cs.OH]
RR-2369.pdf (2.18 Mo) Télécharger le fichier
inria-00074307 , version 1 (24-05-2006)
  • HAL Id : inria-00074307 , version 1
Philippe Flajolet, Xavier Gourdon, Philippe Dumas. Mellin Transforms and Asymptotics: Harmonic Sums. [Research Report] RR-2369, INRIA. 1994. ⟨inria-00074307⟩
197 Consultations
1257 Téléchargements
