Optimization of the number of transportation devices in a flexible manufacturing system using event graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
An important step when designing a Flexible Manufacturing System (FMS) using Automated Guided Vehicles (AGVs) is the definition of the number of AGVs to be used in order to reach a given productivity. A way to define this number is to consider several scenari, to define the minimal number of AGVs required by each scenario, and to keep the maximal of these numbers. In this paper, we propose a Branch and Bound (B&B) approach to define the minimal number of AGVs require for a scenario. This approach is based on an Event Graph (EG) formulation.
RR-2359.pdf (783.1 Ko) Télécharger le fichier
inria-00074318 , version 1 (24-05-2006)
  • HAL Id : inria-00074318 , version 1
Jean-Marie Proth, Nathalie Sauer, Xiaolan Xie. Optimization of the number of transportation devices in a flexible manufacturing system using event graphs. [Research Report] RR-2359, INRIA. 1994, pp.18. ⟨inria-00074318⟩
85 Consultations
136 Téléchargements
