Poisson Power Tesselations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
We consider generalization of the Voronoi diagram - power diagram, constructed with respect to a Poisson processes with i.i.d. marks (weights). We give first moment of the volume distribution of a typical cell, the probability that a cell is empty, the mean length of a typical edge in the planar case and other geometrical characteristics of this tesselation.
Autre [cs.OH]
RR-2303.pdf (210.7 Ko) Télécharger le fichier
inria-00074370 , version 1 (24-05-2006)
  • HAL Id : inria-00074370 , version 1
Sergueï Zuyev. Poisson Power Tesselations. [Research Report] RR-2303, INRIA. 1994. ⟨inria-00074370⟩
56 Consultations
74 Téléchargements
