HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Coupling Boltzmann and Navier-Stokes
Abstract : The objective of the present work is the computation of hypersonic flows around reentry vehicles at high altitude. This work was supported by the European project Hermès (ESA funding under contract ALG91/10, ATP DPH n$^\circ$ 6464/91, phase Hermès R/Q) and was performed under the technical supervision of Dassault Aviation. The proposed method couples Boltzmann equations, used next to the body, and Navier-Stokes equations used in the far field. This coupling is imposed without domain overlapping by imposing adequate interface boundary conditions on incoming half-fluxes. These boundary conditions are based on a kinetic interpretation of the Navier-Stokes equations. The numerical implementation of this technique uses a time marching algorithm, a SUPG Navier-Stokes solver developed by Dassault Aviation and solves the Boltzmann equations by a Monte Carlo technique. Different numerical results are finally presented, mainly using a nonadaptative partitioning technique.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074390
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:12:30 PM
Last modification on : Friday, February 4, 2022 - 3:16:33 AM
Long-term archiving on: : Monday, September 17, 2012 - 2:55:16 PM
Identifiers
  • HAL Id : inria-00074390, version 1
Collections
Citation
Jean-François Bourgat, Patrick Le Tallec, François Mallinger, Benoît Perthame, Youchoun Qiu. Coupling Boltzmann and Navier-Stokes. [Research Report] RR-2281, INRIA. 1994. ⟨inria-00074390⟩
Share
Metrics
Record views
125
Files downloads
56
