HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Compilation of head and strong reduction
Pascal Fradet 1
1 LSP - Langages et Systèmes Parallèles
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, INRIA Rennes
Abstract : Functional language compilers implement only weak-head reduction. However, there are cases where head normal forms or full normal forms are needed. Here, we study how to use cps conversion for the compilation of head and strong reductions. We apply cps expressions to a special continuation so that their head or strong normal can be obtained by the usual weak-head reduction. We remain within the functional framework and no special abstract machine is needed. Used as a preliminary step our method allows a standard compiler to evaluate under l's.
Document type :
Reports
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/inria-00074540
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:43:01 PM
Last modification on : Friday, February 4, 2022 - 3:25:32 AM
Long-term archiving on: : Monday, April 5, 2010 - 12:11:12 AM
Identifiers
  • HAL Id : inria-00074540, version 1
Citation
Pascal Fradet. Compilation of head and strong reduction. [Research Report] RR-2132, INRIA. 1993. ⟨inria-00074540⟩
Share
Metrics
Record views
75
Files downloads
99
