Static domain analysis for compiling commutative loop nests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
In the field of scientific computation, many users wish to use the sequential programming model, even though they aim to execute their program on a Distributed Memory Parallel Computer (DMPC). To meet this demand, some prototypes of compilers have been designed to "distribute" sequential programs onto DMPCs. In this paper, we present a static domain analysis which leads to the generation of efficient code for these machines. This analysis relies on the enumeration of the points of a polyhedron which is based on linear and integer programming.
Autre [cs.OH]
RR-2067.pdf (212.45 Ko) Télécharger le fichier
inria-00074605 , version 1 (24-05-2006)
  • HAL Id : inria-00074605 , version 1
Marc Le Fur, Jean-Louis Pazat, Françoise André. Static domain analysis for compiling commutative loop nests. [Research Report] RR-2067, INRIA. 1993. ⟨inria-00074605⟩
84 Consultations
104 Téléchargements
