HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Motion of points and lines in the uncalibred case
Thierry Viéville 1 Quang-Tuan Luong 1
1 ROBOTVIS - Computer Vision and Robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : In the present paper we address the problem of computing structure and motion, given a set point and/or line correspondences, in a monocular image sequence, when the camera is not calibrated. We first describe an algebraic approach of the problem and then relate the different equations to a specific geometric construction which allows to solve the motion problem. An implementation is proposed and experimental results are provided.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074618
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:54:51 PM
Last modification on : Friday, February 4, 2022 - 3:16:11 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 5:48:57 PM
Identifiers
  • HAL Id : inria-00074618, version 1
Collections
Citation
Thierry Viéville, Quang-Tuan Luong. Motion of points and lines in the uncalibred case. [Research Report] RR-2054, INRIA. 1993. ⟨inria-00074618⟩
Share
Metrics
Record views
35
Files downloads
41
