A Min-Max certainty equivalence principle for non-linear discrete-time control problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
We extend to a setup comparable to that provided in a recent paper coauthored with Alain Rapaport ( report 2019) for the continuous time case, the main result of our paper (report 2020) in the discrete time case, thus obtaining the most comprehensive certainty equivalence principle for the discrete time problem todate.
Autre [cs.OH]
RR-2031.pdf (409.68 Ko) Télécharger le fichier
inria-00074640 , version 1 (24-05-2006)
  • HAL Id : inria-00074640 , version 1
Pierre Bernhard. A Min-Max certainty equivalence principle for non-linear discrete-time control problems. [Research Report] RR-2031, INRIA. 1993. ⟨inria-00074640⟩
64 Consultations
42 Téléchargements
