HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Codes and finite geometries
Abstract : We explore the connections between finite geometry and algebraic coding theory, giving a rather full account of the Reed-Muller and generalized Reed-Muller codes. Some of the results and many of the proofs are new but this is largely an expository effort that relies heavily on the work of Delsarte et al. and of Charpin. The necessary geometric background is sketched before we begin the discussion of the Reed-Muller codes and their p-ary analogues. We prove all the classical results concerning these codes and include a discussion of the group-algebra approach and prove Berman's theorem characterizing the codes as powers of the radical. Included also is a discussion of the characterization of affine-invariant cyclic codes given by Kasami, Lin and Peterson and its generalization by Delsarte. our theme throughout this work is the relationship between these codes and the codes coming from both affine and projective geometries. The final section develops the theory in the more difficult case in which the field is not of prime order, here must look at subfield subcodes - which complicates the connection with the geometric codes, which are codesover the prime subfield of the field of the geometry.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00074644
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 3:58:53 PM
Last modification on : Friday, February 4, 2022 - 3:10:31 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 5:58:16 PM
Identifiers
  • HAL Id : inria-00074644, version 1
Collections
Citation
Edwar F. Jr Assmus, Jennifer D. Key. Codes and finite geometries. [Research Report] RR-2027, INRIA. 1993. ⟨inria-00074644⟩
Share
Metrics
Record views
84
Files downloads
46
