Analysis of functions with a finite number of return values - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1992
Paul Zimmermann
A class of functions with a finite number of return values is defined over combinatorial structures. We prove that the characterization of combinatorial structures by such a function is equivalent to a set of grammar productions and we show how to derive these productions from the body of the function. In the field of automatic average case analysis, this result allows the use of functions, which makes the description of algorithms more natural and smaller
Autre [cs.OH]
RR-1625.pdf (357.68 Ko) Télécharger le fichier
inria-00074936 , version 1 (24-05-2006)
  • HAL Id : inria-00074936 , version 1
Paul Zimmermann. Analysis of functions with a finite number of return values. [Research Report] RR-1625, INRIA. 1992. ⟨inria-00074936⟩
65 Consultations
60 Téléchargements
