Phase transition in a loss load sharing model - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1992
In this paper we analyze the following loss network : when a customer arrives at a node of the network, it is served by this node if this one is not occuped, otherwise it is transmitted to some empty node where it will be served with another rate. For simplest systems of such type with very large number of nodes with global sharing we show the existence of second order phase transitions and present explicit formulas for probability characteristics. For local sharing, we study the case of the infinite network and present some convergence results, formulas for small and large loads are obtained.
RR-1602.pdf (297.99 Ko) Télécharger le fichier
Dates and versions
inria-00074958 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00074958 , version 1
Cite
Vadim A. A. Malyshev, Philippe Robert. Phase transition in a loss load sharing model. [Research Report] RR-1602, INRIA. 1992. ⟨inria-00074958⟩
60 View
52 Download
Share
