Non-linear vector interpolation by neural network for phoneme identification in continuous speech - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1991
Yifan Gong
  • Fonction : Auteur
Jean-Paul Haton
  • Fonction : Auteur
  • PersonId : 830987
The coorelation between vectors in a sequence of analysis frames are supposed to be specific to phonetic units in acoustic-phonetic decoding of speech. We propose non-linear vector interpolation techniques to represent this correlation and to recognize phonemes. The interpolation is based on the decomposition of a frame sequence into two parts and on the construction of a function that interpolates one part using information from the second part. According to quantities to be interpolated, three families of interpolator models are developed. In a recognition system, each phonetic symbol is associated with a non-linear vector interpolator which is trained to give minimum interpolation error for that specific phoneme. Multi-layer feedforward neural networks are used to implement the non-linear vector interpolators. For a continuous speech phoneme spotting test using 16 LPCC-derived cepstrum coefficients as parametric vectors, the three categories of models gave compatible results. Vector-pair interpolator models yielded best recognition rate. Compared to a VQ-coded reference technique, this model gives close global recognition rate and significatly outperforms for plosive sounds.
Autre [cs.OH]
RR-1457.pdf (721.91 Ko) Télécharger le fichier
inria-00075104 , version 1 (24-05-2006)
  • HAL Id : inria-00075104 , version 1
Yifan Gong, Jean-Paul Haton. Non-linear vector interpolation by neural network for phoneme identification in continuous speech. [Research Report] RR-1457, INRIA. 1991. ⟨inria-00075104⟩
81 Consultations
95 Téléchargements
