Transformation of polynomial differential systems in the positive orthant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1990
We study polynomial n-dimensional differential systems when the (n-dimensional) variable keeps the same sign; that is, the system is defined inside one of the orthants. We show it is always possible to transform the system into a quadratic Lotka-Volterra type system. We give several tools to study these last systems; we deduce indications on the global behaviour of the original system.
Autre [cs.OH]
RR-1308.pdf (368.8 Ko) Télécharger le fichier
inria-00075251 , version 1 (24-05-2006)
  • HAL Id : inria-00075251 , version 1
Jean-Luc Gouzé. Transformation of polynomial differential systems in the positive orthant. [Research Report] RR-1308, INRIA. 1990, pp.10. ⟨inria-00075251⟩
131 Consultations
48 Téléchargements
