HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Equivalence, reversibility and symmetry properties in fork/join queueing networks with blocking
Abstract : In this paper we study quantitative as well as qualitative properties of Fork/Join queueing networks with blocking (FJQN/B's). Specifically, we prove theorems regarding the equivalence of the behavior of a FJQN/B and that of its duals of a circuit-free FJQN/B, and a strongly connected marked graph. In addition, we obtain general conditions that must be satisfied by the service times to guarantee the existence of a long term throughput and its independence on the initial configuration. We also establish conditions under which the reverse of a FJQN/B has the same throughput as the original network. Last, by combining the equivalence results for duals and the reversibility results, we establish a symmetry property for the throughput of a FJQN/B.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00075292
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 5:53:19 PM
Last modification on : Thursday, February 3, 2022 - 11:10:28 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 10:22:12 PM
Identifiers
  • HAL Id : inria-00075292, version 1
Citation
Yves Dallery, Zhen Liu, Don Towsley. Equivalence, reversibility and symmetry properties in fork/join queueing networks with blocking. [Research Report] RR-1267, INRIA. 1990. ⟨inria-00075292⟩
Share
Metrics
Record views
285
Files downloads
49
