Operational semantics of a distributed object-oriented language and its Z formal specification - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1990
PolyGoth is a distributed programming language that integrates the class abstraction of languages like Simula, SmallTalk, Pool or Eiffel with a parallel block structuring concept and its associated notations, namely multiprocedures and fragments. The concepts and notations introduced in PolyGoth enable programmers to address distribution issues in a novel and structured way. To avoid useless complexity, a kernel of the language is used to exhibit the semantics of its most interesting constructs. The semantics is given in an operational way that is based on a transition system. The Z specification language is used to describe the semantics. This novel use of a specification language greatly enhances the structure of the description, its rigorousness, and perhaps, its use fulness.
RR-1230.pdf (3.98 Mo) Télécharger le fichier
Dates and versions
inria-00075328 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00075328 , version 1
Cite
Marc Benveniste. Operational semantics of a distributed object-oriented language and its Z formal specification. [Research Report] RR-1230, INRIA. 1990. ⟨inria-00075328⟩
79 View
37 Download
Share
