HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Unstructured multigridding by volume agglomeration : current status
Abstract : We describe a multigrid method for solving the Euler equations applying to non-structured meshes in 2-D (triangles) and 3-D (tetrahedra). The main idea is to coarsen the given mesh by using topological neighboring relations. It is applied to upwind solvers relying on the MUSCL methodology. Two multigrid schemes are presented : an explicit Runge-Kutta FAS one and an implicit correction scheme. Transonic external flows computations are described for illustration.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00075334
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 5:59:42 PM
Last modification on : Friday, February 4, 2022 - 3:17:25 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 10:38:04 PM
Identifiers
  • HAL Id : inria-00075334, version 1
Collections
Citation
Marie-Hélène Lallemand, Hervé Steve, Alain Dervieux. Unstructured multigridding by volume agglomeration : current status. [Research Report] RR-1224, INRIA. 1990. ⟨inria-00075334⟩
Share
Metrics
Record views
72
Files downloads
139
