Abstract : The theory of Kalman filtering is extended to the case of systems with descriptor dynamics. Explicit expressions are obtained for this descriptor Kalman filter allowing for the possible singularity of the observation noise covariance. Asymptotic behavior of the filter in the time-invariant case is studied ; in particular, a method for constructing the solution of the algebraic descriptor Riccati equation is presented.
