HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
On the optimal stochastic scheduling of out-forests
Abstract : This paper presents new results on the problem of scheduling jobs on K ³ 1 parallel processors so as to minimize stochastically the makespan. The jobs are subject to out-forest precedence constraints, i.e. each job has at most one immediate predecessor, and job running times are independent samples from a given exponential distribution. We define a class of uniform out-forests in which all subtrees are ordered by an embedding relation. We prove that an intuitive greedy policy is optimal for K = 2, and that if out-forests satisfy an additional, uniform root-embedding constraint, then the greddy policy is optimal for all K ³ 2.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00075402
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Wednesday, May 24, 2006 - 6:09:04 PM
Last modification on : Friday, February 4, 2022 - 3:22:03 AM
Long-term archiving on: : Tuesday, April 12, 2011 - 10:57:54 PM
Identifiers
  • HAL Id : inria-00075402, version 1
Collections
Citation
Edward G. Coffman, Zhen Liu. On the optimal stochastic scheduling of out-forests. [Research Report] RR-1156, INRIA. 1990. ⟨inria-00075402⟩
Share
Metrics
Record views
45
Files downloads
115
