Third-order finite element schemes for the solution of hyperbolic problems - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 1987
Disponible dans les fichiers attachés à ce document
RR-0707.pdf (708.94 Ko) Télécharger le fichier
Dates and versions
inria-00075845 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00075845 , version 1
Cite
Vittorio Selmin. Third-order finite element schemes for the solution of hyperbolic problems. [Research Report] RR-0707, INRIA. 1987. ⟨inria-00075845⟩
44 View
69 Download
Share
