Solving disequations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1987
Claude Kirchner
Pierre Lescanne
  • Fonction : Auteur
We present a general study of equations (objects of form s=t and disequations (objects of form s \ne t) solving. The problem is approached from its fully general mathematical definition clearly separating universally and existentially quantified variables. In addition it is showed to have many connections with unification in equational theories like associativity commutativity, in particular methods similar to those used to solve equational unification problem works in solving disequations. This abstract framework is then applied to study the sufficient completeness of a rewrite rule based definition of a function.
Autre [cs.OH]
RR-0686.pdf (749.79 Ko) Télécharger le fichier
inria-00075867 , version 1 (24-05-2006)
  • HAL Id : inria-00075867 , version 1
Claude Kirchner, Pierre Lescanne. Solving disequations. [Research Report] RR-0686, INRIA. 1987. ⟨inria-00075867⟩
175 Consultations
69 Téléchargements
