HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Stationary IPA estimates for non-smooth functions of the GI/G/1/infini workload
Abstract : We give stationary estimates for the derivative of the expectation of a non-smooth function of bounded variation f of the workload in a GI/G/1/ queue, with respect to a parameter influencing the distribution of the input process. For this, we use an idea of Konstantopoulos and Zazanis based on the Palm inversion formula, however avoiding a limiting argument by performing the level-croissant analysis there of globally, via Fubini's theorem. This method of proof allows to treat the case where the workload distribution has a mass at discontinuities of f and where the formula has to be modified. The case where the parameter is the speed of service or/and the time scale factor of the input process is also treated using the same approach.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00076900
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Monday, May 29, 2006 - 11:17:34 AM
Last modification on : Friday, February 4, 2022 - 3:08:12 AM
Long-term archiving on: : Monday, April 5, 2010 - 9:21:23 PM
Identifiers
  • HAL Id : inria-00076900, version 1
Collections
Citation
Pierre Brémaud, Jean-Marc Lasgouttes. Stationary IPA estimates for non-smooth functions of the GI/G/1/infini workload. [Research Report] RR-1677, INRIA. 1992. ⟨inria-00076900⟩
Share
Metrics
Record views
55
Files downloads
51
