Reports
Fractal approximation of 2-D object
Abstract : We present some new techniques for shape approximation with fractals, using iterated function system, a powerful method which allows good control on the resulting fractal. The main point discussed here can be stated as follows : given a grey level image A, find a few number of functions and associated probabilities that approximately generate A. Two directions have been explored : the first uses a gradient method, thus it was necessary to define a smooth error function ; the second one is based upon the ideas of simulated annealing. We then generalize the methods to a broader class of functions, and present some results.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/inria-00077101
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Monday, May 29, 2006 - 2:48:04 PM
Last modification on : Friday, February 4, 2022 - 3:10:26 AM
Long-term archiving on: : Tuesday, September 18, 2012 - 11:25:26 AM
Identifiers
  • HAL Id : inria-00077101, version 1
Collections
Citation
Jacques Lévy Véhel, André Gagalowicz. Fractal approximation of 2-D object. [Research Report] RR-1187, INRIA. 1990. ⟨inria-00077101⟩
Share
Metrics
Record views
108
Files downloads
126
