New interface
Reports (Research report)
The Inverse EEG and MEG Problems : The Adjoint State Approach I: The Continuous Case
Abstract : In this report, we study the problem of the three-dimensional reconstruction of the electrical activity of the brain from electroencephalography (EEG) and magnetoencephalography (MEG). We use a variational approach based upon three main methods and ideas. The first one is the optimal control of systems governed by elliptic partial differential equations, the second is the regularization of the solutions while preserving the discontinuities (the edges), and the third one is the use of geometric information obtained from magnetic resonance images (MRI) to constrain the solutions in an anatomically «reasonable» way.
Document type :
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/inria-00077112
Contributor : Rapport De Recherche Inria Connect in order to contact the contributor
Submitted on : Monday, May 29, 2006 - 2:50:26 PM
Last modification on : Thursday, October 27, 2022 - 4:02:45 AM
Long-term archiving on: : Monday, April 5, 2010 - 9:38:25 PM
Identifiers
  • HAL Id : inria-00077112, version 1
Citation
Olivier Faugeras, François Clément, Rachid Deriche, Renaud Keriven, Théodore Papadopoulo, et al.. The Inverse EEG and MEG Problems : The Adjoint State Approach I: The Continuous Case. [Research Report] RR-3673, INRIA. 1999, pp.28. ⟨inria-00077112⟩
Share
Metrics
Record views
267
Files downloads
530
