Reports
Dynamic Model of Communicating Hydrocephalus for Surgery Simulation
Olivier Clatz 1, * Stéphane Litrico 2 Hervé Delingette 1 Nicholas Ayache 1
* Corresponding author
1 ASCLEPIOS - Analysis and Simulation of Biomedical Images
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : We propose a dynamic model of cerebrospinal fluid circulation and intracranial pressure regulation. In this model, we investigate the coupling of biological parameters with a 3D model, to improve the mechanical behavior of the brain in surgical simulators. The model was assessed by comparing the simulated ventricular enlargement evolution with a patient case study of communicating hydrocephalus. In our model, cerebro-spinal fluid production-resorption system is coupled with a 3D representation of the brain parenchyma. We introduce a new bi-phasic model of the brain tissue allowing for fluid exchange between the brain extracellular space and the venous system. The time evolution of ventricular pressure has been recorded on a symptomatic patient after closing the ventricular shunt. A finite element model has been built based on a CT scan of this patient, and quantitative comparisons between measures and simulated data are proposed.
Document type :
Reports
Complete list of metadatas
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/inria-00080553
Contributor : Rapport de Recherche Inria <>
Submitted on : Tuesday, June 20, 2006 - 4:55:07 PM
Last modification on : Thursday, February 7, 2019 - 5:08:20 PM
Document(s) archivé(s) le : Monday, June 27, 2011 - 3:29:17 PM
Identifiers
  • HAL Id : inria-00080553, version 2
Collections
Citation
Olivier Clatz, Stéphane Litrico, Hervé Delingette, Nicholas Ayache. Dynamic Model of Communicating Hydrocephalus for Surgery Simulation. [Research Report] RR-5934, INRIA. 2006, pp.20. ⟨inria-00080553v2⟩
Share
Metrics
Record views
431
Files downloads
551
