Fast algorithms for computing isogenies between elliptic curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We survey algorithms for computing isogenies between elliptic curves defined over a field of characteristic either 0 or a large prime. We introduce a new algorithm that computes an isogeny of degree $\ell$ ($\ell$ different from the characteristic) in time quasi-linear with respect to $\ell$. This is based in particular on fast algorithms for power series expansion of the Weierstrass $\wp$-function and related functions.
BoMoSaSc06.pdf (305.11 Ko) Télécharger le fichier
inria-00091441 , version 1 (06-09-2006)
Alin Bostan, Bruno Salvy, Francois Morain, Eric Schost. Fast algorithms for computing isogenies between elliptic curves. [Research Report] 2006, pp.28. ⟨inria-00091441⟩
1245 Consultations
306 Téléchargements
