Solving superelliptic diophantine equations by Baker's method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Compositio Mathematica Année : 1998
Yuri Bilu
Guillaume Hanrot
  • Fonction : Auteur
  • PersonId : 831392
We describe a method for complete solution of the superelliptic Diophantine equation ay^p=f(x). The method is based on Baker's theory of linear forms in the logarithms. The characteristic feature of our approach (as compared with the classical method is that we reduce the equation directly to the linear forms in logarithms, without intermediate use of Thue and linear unit equations. We show that the reduction method of Baker and Davenport is applicable for superelliptic equations, and develop a very efficient method for enumerating the solutions below the reduced bound. The method requires computing the algebraic data in number fields of degree pn(n-1)/2 at most; in many cases this number can be reduced. Two examples with p=3 and n=4 are given.
inria-00098523 , version 1 (25-09-2006)
Yuri Bilu, Guillaume Hanrot. Solving superelliptic diophantine equations by Baker's method. Compositio Mathematica, 1998, 112 (3), pp.273--312. ⟨10.1023/A:1000305028888⟩. ⟨inria-00098523⟩
130 Consultations
0 Téléchargements
