On the Complexity of Counting the Hilbert Basis of a Linear Diophantine System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
We investigate the computational complexity of counting the Hilbert basis of a homogeneous system of linear Diophantine equations. We establish lower and upper bound on the complexity of this problem by showing that counting the Hilbert basis is #P-hard and belongs to the class #NP. Moreover, we investigate the complexity of variants obtained by restricting the number of occurrences of the variables in the system.
Fichier non déposé
inria-00098565 , version 1 (25-09-2006)
  • HAL Id : inria-00098565 , version 1
Miki Hermann, Laurent Juban, Phokion G. Kolaitis. On the Complexity of Counting the Hilbert Basis of a Linear Diophantine System. [Intern report] 98-R-281 || hermann98c, 1998, 16 p. ⟨inria-00098565⟩
94 Consultations
0 Téléchargements
