Retrospective Conversion of Old Bibliographic Catalogues - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Abdel Belaïd
  • Fonction : Auteur
This paper describes a framework for retrospective document conversion in the library domain. Drawing on the experience and insight gained from the {\sc more} project launched over the present decade by the European Commission, it outlines the requirements for solving the problem of retroconversion of old catalogues in {\sc unimarc} format. Based on {\sc ocr} technique and automatic structure recognition, the system proposes a direct schema for the conversion of references in machine readable records. Furthermore, as the system is meant for a real production chain, the paper describes the industrial constraints and gives a complete benchmark realised on this chain for 11 volumes and 4568 references. Without any manual intervention, the recognition rate of the system is greater than 75\%
Autre [cs.OH]
Fichier non déposé
inria-00098578 , version 1 (25-09-2006)
  • HAL Id : inria-00098578 , version 1
Abdel Belaïd. Retrospective Conversion of Old Bibliographic Catalogues. Six DELOS Workshop, Preservation of Digital Information, 1998, Tomar, Portugal, 10 p. ⟨inria-00098578⟩
26 Consultations
0 Téléchargements
